June 6, 2022 at 10:32 am
FAQParticipantIn ANSYS Meshing, Named Selections can be used to select or filter a set of geometric entities, like edges or faces, by using a criterion like size, type, or location.
Please follow these steps to create a worksheet driven Named Selection:
1.Select geometry (e.g. edge or surface)
2.Right-Click > Create Named Selection.
3.Activate “Apply geometry items of same:” and select one of the 5 types (Size, Type, Location x, Location y, Location z).
Note: This selection can be changed later, so feel free to select any one of the available checkboxes.
4.Press OK.
In the Tree, select the Named Selection and a Worksheet will appear. In the Worksheet, the desired criteria for automatic selection of other geometry entities can now be defined by choosing an Action, Criterion, Operator, and Value.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
