A pbs script got created by the Fluent launcher is for the korn shell i.e. the script was having #!/bin/ksh in its 1st line. Instructions will let you know what is the argument needed to pass in the Fluent command line for the script to be created for the bash shell
Tagged: 2021 R1, bash, FLUENT - SYS, HPC/Parallel, Installation/Licensing/Systems, ksh, pbs
March 17, 2023 at 9:00 am
FAQParticipantChange from ksh to bash in line # 92 in /ansys_inc/v211/fluent/bin echo “#!/bin/ksh ” > ${FL_SCHEDULER_SCRIPT_FILE}
