A local Linux machine is connected to a Windows machine through Samba. While trying to run CFX Solver remotely on Windows through Samba, the following error appears: Error copying MMS input file mms for reading: Operation not supported.
March 17, 2023 at 9:01 am
FAQParticipantSymlinks will not work over Samba. The code expects this and checks for an “Operation not permitted†error. If it finds this, it falls back to copying the file. The workaround is to create the file .cfx5rc in the user’s home directory with the line CFX5_DISABLE_SYMLINKS=1.
