A CFX simulation using the discrete transfer radiation model seems to fail randomly and inexplicably. What are the most likely causes and how can this problem be dealt with?
Tagged: 16, cfx, fluid-dynamics, Heat Transfer and Radiation, heat-transfer, Other
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 428169.pdf
- Defining heat transfer coefficient (HTC)
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to use Thin Walls with Thermal boundary conditions?
- Thermal Analysis of a Radiator Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- Simulating Battery Pack Cooling System Using Ansys Fluent
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- What is the difference between internal and external emissivity?
