Tagged: Ansys Discovery, arguments, batch-mode, CMD, COMMAND PROMPT, command-line, FILE PATH, open, prompt, script
April 11, 2024 at 8:24 am FAQParticipant FAQParticipantAnsys Discovery project can be opened in batch mode from Command Prompt (CMD) using below mentioned command: “C:\Program Files\ANSYS Inc\v241\Discovery\Discovery.exe” –open “File Path” Example of File Path: D:\Discovery\Pipe flow.dsco  -o, –open: Project to open at start-up. It is good practice to put quotation marks around the path to the solver executable and around the full path to the project. This ensures that spaces in the path or project are not an issue. Refer this Running Discovery from the Command Line help documentation for supported command-line arguments in Discovery.
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Customizing the Ribbon Tab
- Release Notes- Previous versions
- Top New Features in Ansys Discovery 2025 R2
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Transient Simulation
- Change Language in Discovery
- Ansys Discovery 2025 R1 Capabilities chart
 You are navigating away from the AIS Discovery experience
