Tagged: Analyses, Analysis transfer, Associativity transfer, Boundary condition synchronization, boundary-conditions, connection, Discovery model, Discovery simulation, Dscodat file, Knowledge article, Linking models, Physics transfer, Smart update, Smart Update Associativity Transfer, Transfer to Mechanical, Unidirectional connection, Workbench mechanical
April 10, 2024 at 10:55 am
Watch & LearnParticipantAn interesting new feature has been introduced in the 2024R1 release, where you can do a Smart Update Associativity Transfer. This gives you the ability to link your Discovery model to Mechanical. Analyses, connections and boundary conditions are transferred and tracked. It maintains a unidirectional connection, therefore, if they are modified in Discovery, these changes are propagated in Mechanical.
Please refer to the video below to understand how you can use this feature,
Please refer to the KM regarding Transferring the Discovery simulation to Mechanical (without maintaining the unidirectional connection), mentioned in the video here: Discovery: Transfer to Mechanical
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- Applying Thermal Conductance
