September 22, 2023 at 11:02 am
FAQParticipantWhen analysis is completed in Maxwell, how to export the simulation results/plots of Maxwell? – Select from the menu, Maxwell2D/3D -> Results -> Create Transient Report -> Rectangular Plot. – Select a Quantity of Category in the Report window and press the New Report. – When you right-click in the Plot window “Export” and “Export Legend” show up. Export is saving a waveform by a csv file with X, Y axis values, Export Legend store output data from Trace Characteristics. Keywords : Maxwell, Results, Report, Export, Export Legend
1. EM_FAQ_ExportResultPlots_Maxwell.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- Vacuum Thermal Modeling in ANSYS Icepak
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
