Tagged: 18.2, contact, General, mechanical, structural-and-thermal, structural-mechanics
August 25, 2023 at 12:16 pm
SolutionParticipantYes it’s possible. For that you need to define a table with APDL and modify CNOF to make it function of a table. *DIM,cnof,table,7,1,,Y! Define a new table variable ‘cnof’ as a function of Y cnof(1,0) = -35000! Define the row 1 (Y) of the table cnof(2,0) = -30000 cnof(3,0) = -25000 cnof(4,0) = -20000 cnof(5,0) = -15000 cnof(6,0) = -10000 cnof(7,0) = -5000 cnof(1,1) = 0.0! Define row 2(Offset) of the table cnof(2,1) = 0.01 cnof(3,1) = 0.02 cnof(4,1) = 0.025 cnof(5,1) = 0.02 cnof(6,1) = 0.01 cnof(7,1) = 0.0 RMODIF,cid,10,%cnof%! Modify the real constant 10 of the contact elements ‘cid’ Please find attached an example
1. 2052095.zip
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
