Tagged: 18.2, contact, General, mechanical, structural-and-thermal, structural-mechanics
August 25, 2023 at 12:16 pm
SolutionParticipantPlease refer to the attachments to access the solution.
1. 2051294.pdf
2. 2051294.zip
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
