August 25, 2023 at 12:16 pm
SolutionParticipantThis is currently not possible through the Mechanical GUI. However, you can accomplish this through the use of a commands object as described in the attachments. Also, consider using a smaller unit for time as an alternative to using very small numbers.
1. 2044670.pdf
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
