Where do I find the information on the total mass, the centre of gravity, and the inertia moments when point masses are included in the model?
August 25, 2023 at 12:16 pm
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
