August 25, 2023 at 12:16 pm SolutionParticipant SolutionParticipantThis video is from an internal meeting that highlights the following relevant knowledge material articles. 2047442: Icepak 18.0 error when starting 2046766: License required to import DesignModeler geometry into SpaceClaim 2046596: How to remove hung licenses 2044370: Step file import fails in SpaceClaim 2048358: Meshing error 2046936: Solver module error when starting This video and the associated presentation are made available to our customers in hopes that you will find the technical content useful. Please refer to the attachments to access the video and the related presentation. Attachments:
 1. 2048978.pdf
 2. 2048978_NewSolutions10.mp4
 You are navigating away from the AIS Discovery experience
