August 25, 2023 at 12:16 pm
SolutionParticipantThis tutorial demonstrates executing a sequence of one-way thermal transfers in a heat exchanger using the System Coupling infrastructure. For instructions, see page 39 in the document ‘ANSYS System Coupling Tutorials’. Please refer to the attachments to access the Solution.
1. 2048026.zip
2. SystemCouplingTutorials_R172.pdf
- Skewness in ANSYS Meshing
