General
General
How do I run a calculation with a journal file?
    • FAQFAQ
      Participant
      Please refer to the below for the solution: /file/read-case-data filename.cas /solve/it 3000  **Constant Calculation /solve/dti 200 20 **Unsteady 200:Number of timesteps, 20:Max iteration number /file/write-case-data filename.cas **In the case of a non-steady-state calculation, set autosave in advance
      1. 2041857.pdf
