How to access the Monitor Statistics from a Monitor Point as an output parameter in ANSYS Workbench?
Tagged: 17.2, cfx, expressions, fluid-dynamics, General - CFX, Monitor Statistics, workbench
August 25, 2023 at 12:15 pm
SolutionParticipantLet us calculate an arithmetic average of an expression on a Monitor Point. Can the arithmetic average be accessed as an output parameter in a parametric run? How this can be achieved is described in the attached document and example.
1. 2045988.pdf
2. 2045988.zip
- Skewness in ANSYS Meshing
