How to improve the ANSYS CFX Solver stability when using material properties depending on solution variables?
August 25, 2023 at 12:15 pm
SolutionParticipantIf variable properties are used for describing correctly the fluid or solid material behavior, failures or warring messages about properties going out of bounds are often observed with the ANSYS CFX Solver. What is causing this behavior and how can it be avoided? Please find a description and an example attached.
1. 2045987.pdf
- Skewness in ANSYS Meshing
