ANSYS SpaceClaim: How to define parameter for revolve option within Pull tool? Or how to define parameter for angle of revolution?
August 25, 2023 at 12:15 pm
SolutionParticipantParameter for angle of revolution can be defined by first creating an angular dimension and then using Move tool to create a parameter. Please refer attached solution for more details.
1. 2050936.mp4
2. 2050936.pdf
- Skewness in ANSYS Meshing
