August 25, 2023 at 12:15 pm
FAQ
ParticipantVolumetric sweep is done using Pull feature. You need to select a solid body and sweep it along an arbitrary path. The result is a faceted body that is useful for creating and visualizing motion paths or envelopes, or for creating cuts from the path of a moving tool bit in machining operations. Please find attached a couple of snapshots showing Volumetric sweep.
1. 2050541.zip
- Skewness in ANSYS Meshing
