ANSYS SpaceClaim: I’m trying to rotate a dimension from horizontal to vertical. I can’t seem to figure out how to do this. Is this possible?
August 25, 2023 at 12:15 pm
FAQ
ParticipantIf you’re referring to the actual dimension text, you should see an option on the left side of the screen, under the structure tree. That will allow you to control the text orientation. Refer attached image which shows these options.
- Skewness in ANSYS Meshing
