ANSYS SpaceClaim: Can I save and export my application preference setting in a file and share with others?
Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General, geometry
August 25, 2023 at 12:15 pmFAQParticipant
In the advanced options, all the way to the right, you can import, export, and clear your settings. Refer attached image which shows this option.
Attachments::
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
