Tagged: 17.2, designmodeler, fluid-dynamics, geometry, Modify Geometry, thin-surface
August 25, 2023 at 12:15 pm
SolutionParticipantPlease refer to the attachment to access the solution.
1. 2046336.pdf
- Skewness in ANSYS Meshing
