General
General
I am using the Pre Inflation (Fliuent Meshing) option in ICEM and am encountering the following error as it launches: An Internal error has occurred: can’t read “mesh_OUT”: no such variable What does this mean and how can I get around it?
    • FAQFAQ
      Participant
      Fluent meshing operates from a volume mesh and requires this as an input. The error is thrown because there is no input volume mesh for Fluent Meshing to operate on. If you generate the volume mesh, Pre Inflation will run normally.
