I am trying to scale geometry about a local coordinate system (LCS) in ICEMCFD, but I don’t get the transformation I expect. For instance, my geometry shifts even though I have only specified a scaling about its centroid.
June 5, 2023 at 7:06 am
FAQParticipantThere is a Linux – only defect that affects transformations about LCS for ICEMCFD R17.0 onwards. To work around this, either work on a Windows platform or use V 16.2 on Linux. The defect is scheduled to be fixed in R18.2
- Skewness in ANSYS Meshing
