Why is the ‘Ruler’ display not available in Fluent anymore? I try to change it but the option to display it is greyed out.
Tagged: 18.2, fluent, fluent-post-processing, fluid-dynamics, post-processing
June 5, 2023 at 7:06 am
FAQ
ParticipantThe Ruler display is only available when using ‘orthographic’ projection, not ‘perspective’. The projection mode can be changed in the ‘Camera Parameters’ dialogue box, accessed from ‘Viewing->Camera’.
- Skewness in ANSYS Meshing
