June 5, 2023 at 7:06 am
FAQParticipantCAD Assembly is beta feature. In GUI you can update it by using RMB. In console you can use following. /cad-assemblies/update-cad-assemblies |test.scdoc , You just needs to append “|” to the top assembly name and if you need to update specific body under it keep appending using: “|” and further tree hierarchy
- Skewness in ANSYS Meshing
