Tagged: 18, FLUENT - SYS, graphics, Installation/Licensing/Systems, Other
June 5, 2023 at 7:06 am
FAQParticipantApplies to all versions of Fluent We have seen this a few times and have traced it to instead of installing the Nvidia package manager (for graphics) from your Linux installation you must install Nvidia drivers manually from the Nvidia webpage. The package manager system Nvidia install does not work. It is because the following 32-bit libraries are not installed by the system package manager and is by the Nvidia install: with the following libraries in /usr/lib libGLESv1_CM.so.1 libGLESv1_CM.so.340.96 libGLESv1_CM.so libGLESv2.so.2 libGLESv2.so.340.96 libGLESv2.so libGL.la libGL.so
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
