Is computation of radiation possible within a multilayer shell wall in Fluent? E. g. for simulating a heat resistance.
June 5, 2023 at 7:06 am
FAQParticipantImagine the case where a small air gap is in between two solid bodies, the solid bodies and the air gap are modeled as a multilayer shell conduction wall. The air gap acts as a heat resistance for the heat flow. In reality for high temperatures radiation through the air gap between the two solids might have a large impact on the transferred heat flow. This cannot be modelled using the multilayer shell conduction wall model. The air gap has to be modeled as a cell zone instead.
- Defining heat transfer coefficient (HTC)
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to use Thin Walls with Thermal boundary conditions?
- Thermal Analysis of a Radiator Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- Simulating Battery Pack Cooling System Using Ansys Fluent
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- What is the difference between internal and external emissivity?
