Licensing
Licensing
Remote job submitted from Mechanical to RSM 18.0 integrated with LSF, Mechanical GUI and Job Monitor closed after job is submitted and running. After some time (a few hours or days), reopen his WB project found many below errors in Job Monitor: External operation: ‘queryStatus’ has failed. This may or may not become a fatal error Problem during Status. The parser was unable to parse the output and did not output the variable: RSM_HPC_OUTPUT_STATUS. Error: Job is not found … Status Failed Problem during Status. The parser was unable to parse the output and did not output the variable: RSM_HPC_OUTPUT_STATUS. Error: Job is not found
    • FAQFAQ
      Participant
      Check and apply the fix in Solution # 2048581 first. Workarounds: #1: Increase CLEAN_PERIOD in lsb.params (the default period is 1 hour) to long enough time (e.g. 1 or some days), make sure when WB project and Mechanical is reopened, RSM client can find LSF job status (e.g. DONE or RUNNING) Or #2: Keep 18.0 Mechanical GUI open while the RSM > LSF job is running. Or #3: Upgrade to R18.1, open the standalone “RSM Job Monitoring 18.1” on client (Start > ANSYS 18.1 > Remote Solve Manager), select the running job and click the “Enabling Live Job Monitoring” button to enable real-time fresh mode. Keep “RSM Job Monitoring” open while RSM job is running. Workbench and Mechanical can be closed.
