ANSYS SpaceClaim: Floating license server doesn’t release the licenses when the user shut downs SpaceClaim. How to overcome this issue?
June 5, 2023 at 7:05 am
FAQParticipantThis issue can have many causes: 1. SpaceClaim.exe process remains active in the Task Manager on the user’s machine. This is sometimes related to certain Add Ins. Check the options and disable any unused add ins. A temporary fix would be stopping the process manually in Windows. 2. Network delay causes slow server update There could be various network issues that might cause this. There might be some other reasons, but these are the most common.
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
