Are the number in the license usage table related to the maximum usage of the license key in a day or the number of calls to the license key during the day?
June 5, 2023 at 7:05 am
FAQParticipantLicense peak usage will show you the peak usage of certain license feature and this is then related to the concurrent usage of the license feature. Example: Starting SpaceClaim and Closing it will result in “1” as peak number of usage If one does not close SpaceClaim and open a new SpaceClaim session it will augment the peak number into “2”. For Week and Month columns averaged values are shown. Example for a week the value which you will get is the sum of peak values on every day divided by 7 days and then rounded.
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
