June 5, 2023 at 7:05 am
FAQParticipantWhole warning message: “Warning: zone of type interior found between different solids! Material of cell zone x is aluminum, while material of cell zone y is steel. This will adversely affect the solution.” This message appears if you use a case file that has a surface with type ‘interior’ between two solid cell zones that have different solid material types. The warning has the following reason: the discontinuity in thermal conductivity where two different solid materials meet is treated more accurately if there is a wall/wall-shadow pair. When there is an interior face zone between the materials, harmonic averaging is used to evaluate the thermal conductivity at the face, which may result in a different conductive flux than what would be calculated at a coupled wall. This may or may not have a noticeable effect on the results, but the coupled wall treatment is always more accurate. This warning occurs when reading the .cas file but also when initializing the calculation. To solve it, type in the message window: (slit-interior-between-diff-solids) or /mesh/modify-zones/slit-interior-between-diff-solids
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
