Error message while opening rst file containing super elements. Error message “Failed to make geometry for domain ‘Default Domain’.”
June 5, 2023 at 7:05 amFAQParticipant
If RST file contain CMS super element then it will not load and will give error. Currently this is limitation.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
