June 5, 2023 at 7:05 am
FAQParticipantA Fluent tetrahedral assembly mesh can be created in Workbench Meshing and imported into CFX as a beta option. In Workbench, go to ‘Tools->Options’, then navigate to ‘Appearance’, and check the ‘Beta Options’ box. Now enable ‘View->Properties’ From Workbench, and when the CFX Setup cell is clicked, enable the option to ‘Allow Assembly Mesh Import (beta)’
- Skewness in ANSYS Meshing
