ANSYS SpaceClaim: I want to create a pattern of holes on a slice of a sphere. The pattern option is not letting me create the pattern on a curved surface.
June 5, 2023 at 7:05 am
FAQ
ParticipantTry using the “Create Patterns” option in the Move tool, placing it at the center of the sphere. When you start rotating the entity to be patterned, it will start creating copies along the spherical surface. You can then enter pattern details like count, angle and so on.
- Skewness in ANSYS Meshing
