I am using Creo’s cabling application to create a model. When I try to open the Creo assembly in SC, the components are empty. If I try to save it as Parasolid from Creo and open this in SC, the *.x_t file is 1KB in size and I get an error that there is “no B-rep data in file”.
June 5, 2023 at 7:05 am
FAQ
ParticipantOne must select the option for surface when exporting to Parasolid. Now the file will be successfully read into SC.
- Skewness in ANSYS Meshing
