June 5, 2023 at 7:05 am
FAQParticipantThis looks like DM file is corrupted. A workaround you can try is as follows. 1. Open a DM session 2. Use File –> Import External Geometry File 3. Import *agdb file of the previous session. This will help you to read file in DM. Keywords: DM error, encountered
- Skewness in ANSYS Meshing
