Is it possible to Move solids in 3D/XYZ space, ie like the Move Body tool, but going to a specific point (not the world origin), keeping the same orientation? (without using Align/setting constraints, and needing to switch them off again)
June 5, 2023 at 7:05 am
FAQParticipantThe move tool has an option called “Enter XYZ coordinates” (the icon looks like a little XYZ next to the ruler option) This will allow a user to move something to a desired position. NOTE: the move tool itself will move to that desired position so anchor it to the correct location on the body. Another way is to use “Upto” option and select a desired position to move solids upto that location.
- Skewness in ANSYS Meshing
