June 5, 2023 at 7:05 am
FAQ
ParticipantThis can be done using Offset tool available in Design tab. Click the tool and then select the outer/inner diameter. After it’s set up, pulling one wall will cause both to change.
- Skewness in ANSYS Meshing
