ANSYS SpaceClaim: If I make a copy of a Solid, how do I then break the relationship between the copy and the original. If I move the original one, the copy also now moves. I want to be able to move them independently.
June 5, 2023 at 7:05 am
FAQParticipantYou should be able to right click the entry in the structure tree and select Source > Make Independent.
- Skewness in ANSYS Meshing
