ANSYS SpaceClaim: When I designed one component, wrong unit was set (cm should be set, but mm was set). Is there anyway to enlarge this component 10 times instead of redesign it?
June 5, 2023 at 7:05 am
FAQParticipantYou can scale a model using the Scale option from within the Pull tool. Start the Pull tool, then select Scale. Choose an anchor point to use as the scaling origin (I use the world origin for this), then click the body from the structure tree. Scale to a value of 10.
- Skewness in ANSYS Meshing
