ANSYS SpaceClaim: Does SpaceClaim offer a way of applying formulas to a table in the same way you would apply a formula in excel? Or perhaps the capability of linking to an excel document (or equivalent) with an existing formula.
June 5, 2023 at 7:05 am
FAQParticipantSpaceClaim has an Excel add in that allows you to control driving dimensions as parameters. This is located in SpaceClaim Options > Add Ins > Excel Dimension Editor. It’s also possible to insert curves using equations under Insert > Equation.
- Skewness in ANSYS Meshing
