General
General
ANSYS SpaceClaim: Is it possible to change units within a document and to keep the values? I. e. 1 inch = 1 mm afterwards?
    • FAQFAQ
      Participant
      It is not possible to do that at the moment. The work around would be: 1. Create a dimension on the model 2. Change the units 3. Go to Pull > Scale. Set your anchor point and select the body from the structure tree 4. You will see a small spark next to the dimension. Click that and enter the desired value. The model should scale to match.
