Tagged: 18.2, contact, General, mechanical, structural-and-thermal, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantHigher contact stiffness gives less penetration which in turn gives better accuracy. But higher contact stiffness is also reflected in global coefficients matrix. Higher coefficients make the matrix more ill-conditioned. A PCG solver is sensitive to the ill-conditioned matrices. Thus it will need more iterations which in turn creates longer solution time.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
