What does the following error message issued during an NLAD solution run refer to? Error: Multiple dimensions detected in the model. This is not supported in rezoning.
June 5, 2023 at 7:05 am
FAQParticipantOne possible explanation is re-zoning does not support meshing with elements having an inconsistent DOF set. (i.e. mix of 2D and 3D element types in same model).
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
