Does elastic foundation stiffness – per- area value is acting in both the axial and shear directions, or is it on axial and free in shear direction?
June 5, 2023 at 7:05 am
FAQParticipantThe “Elastic Foundation Stiffness” (EFS) or “Elastic Support” is a way of specifying a spring stiffness per unit area that only acts in the direction normal (axial) to the face of the element.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
