Tagged: 17.2, contact, mechanical, structural-and-thermal, structural-mechanics
June 5, 2023 at 7:04 am
FAQ
ParticipantTurn off the automatic contact generation on refresh of geometry under connections.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
