June 5, 2023 at 7:04 am
FAQParticipantYou can create element orientation to realign local coordinate systems for elements. Right click geometry object>>insert element orientation More details can be found in ANSYS help: Mechanical Application > Mechanical User’s Guide> Specifying Geometry > Element Orientation
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
