June 5, 2023 at 7:04 am
FAQParticipantELBOW290 doesn’t use Flexibility factor and Stress intensity factor. ELBOW290 does not rely on the calculation of pre-integrated section properties like beam and pipe elements. Its formulation is similar to a cylindrical shell model. This way the element can account for general section deformations like ovalization, non-uniform radial expansion, etc.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
