May 25, 2023 at 7:30 am
Solution
ParticipantPlease see attachment for solution. Keywords: ecad, SIwave, edb, design force
1. 2051527.pdf
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- How to Set “Non-Model” Property to an Object in 3D Layout
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Create Bondwires in 3D Layout ?
