May 15, 2023 at 8:33 am
SolutionParticipantThis demonstration shows how to extend surfaces to remove gaps between them. It also explains some options while doing extend. Keywords: extend, gaps, reapir, clean up, prepare
1. 2052945.zip
2. 2052945_Captions-EN.mp4
- Skewness in ANSYS Meshing
